The other day i was playing minecraft and my GT 210 (Fanless version) hit a peak of 91 Degrees. I'm sure other parts of the PC were getting just as hot. I'm not really comfortable with this and there's not a way i know of to undervolt the card manually (although the card is good about undervolting itself during normal use) and the rest of the components are just as locked(damn near no control over them for temps). Are there any tips you guys and gals can give me to help cool my PC? Anything would help :)
EDIT: I have fans around my room running and the only fan i can mount in my case is exhaust....
Linus once unboxed a Toblerone
https://linustechtips.com/topic/170343-summertime-pc-cooling-tips/
A/C or a bowl of ice and a fan pointing towards your computer.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
fans
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
had that gpu, if you have a spare 3/4pin fan header try and find an old 3/4pin fan and have it blowing at the heatsink, mine used to run around 70*c but i got it to 55 as far as i can remember.was this one
but yeah get a fan blowing at it, depending on your pc case/setup give it a clean out, make sure the rooms cool and got fresh air in (window open).
wanna upload a pic?
edit: have you tried unlocking your sempron yet? i regret selling mine (sempron 140) before trying it, unlocked and overclcoked (usually possible at stock volts, ask @tmcclelland455) they're not bad and thier value/performance shoots up, also gt210s and other low profile htpc cards tend to be great overclockers, you could even play world of tanks i bet (on low but still okay looking) at like 40fps (at 1360x768)
fyi my old rig (given by a friend) had 2x2gb of ddr2 800, a 9400gt and sempron 140 so pretty much the same rig, he played resident evil 5 on it.get world of tanks and hit me up if you do manage to unlock it.
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
wanna upload a pic?
I don't really have a camera that is easily used. Just the front facing one on my iPod 5 (16GB model).....
I'm honestly thinking about just putting the PC on a box in front of a spare box fan i have lying about.
It may sound exaggerated or even archaic, but it works wonderfully.
●CPU: i7-4790K w/H100i ●Mobo: MSI Z97 MPower ●RAM: Corsair 16GB Dominator ●GPU: EVGA ACX SC 780 3GB(X2) ●SSD: 850 Pro 256GB ●Case: 450D ●PSU: AX 860i ●Monitor: Asus PB278Q 1440p
In regards to the Sempron thing, it is worth unlocking the other core (assuming it's not defective and it was locked purely to let AMD sell it as a lower-tier chip). When mine was unlocked and overclocked, it performed moderately well.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
please re-read my post its been updated.
air doesnt cool pc's, just pushin' a ton of air at it with nowhere to go will just fill it with dust, make sure that you have a way of getting hot air out and cool air in.
looking at your case and general setup (google is awesome), if your thinking your sytem is REALLY hot, take the side panel off and lay it on its side, those passive heatsinks dont work very well in standard orientation because heat rises and cant get past the PCB laying the pc down allows hot air to escape.
if you have an old pc laying around or amd heatsink (i still classify your pc as "not old") steal an old amd heatsink fan, they're usually 70mm deltas  ;)
tried to tag you, didnt know if it worked, aren't you glad i nagged at you to unlock that sucker and overclock your 6570? not high performance by any measure but a huge improvement over a single core amiright :D ?
hope it still lives btw.
How would i go about doing so? There's no options or anything regarding ANY features other than boot device changing and shut off temps in my BIOS.
and in regards to your latest post, i may try that in a bit :)
open up your side adn find what board you have and post it here, we'll wait B) ....
RS690M03 right? by foxconn, yep had a foxconn a74ml-k in mine...
unfortuneatly it seems to have a 690 chipset so doesnt have advanced clock calibration so you wont be able to unlock on it, also it wouldnt be worth buying a new board to do it, when you do get a new pc keep your current one or atleast your sempron jsut in case one day you come across a 700+ chipset which does have it, maybe your sempron will lead a future life somewhere in a htpc.
what ive dug up...
https://www.google.co.uk/search?q=M5100+RS690M03&oq=M5100+RS690M03&aqs=chrome..69i57&sourceid=chrome&es_sm=122&ie=UTF-8#q=RS690M03+chipset
https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=690G+unlocking+ACC&spell=1
http://en.wikipedia.org/wiki/AMD_690_chipset_series#690V
open up your side and find what board you have and post it here, we'll wait B) ....
RS690M03 right?
The print where you'd normally read it says "M2N68-LA"
Googleing it gave me the ASUS M2N68-LA
It worked. :P I honestly had forgotten that you told me to unlock it (you told me, I forgot about it, then I fiddled with the BIOS and was like "Hey, that's neat!"). And my 6570 dropped frames like crazy overclocking.
I had almost perfect "scaling," if you will, unlocking the other core.
And I think it will live. It survived close to 5GHz and 1.8v. ;)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
oh, right well not the board i was expecting but i have got a friend with the same board (acer pc, sempron 2100+ dual 1.8ghz) still no dice because it is an nvidia chipset. gutted.(fwiw i sold my gt210 to my aforementioned friend).
yeah so you're stuck as a single core it seems (maybe find a cheap upgrade like an athlon 215 off ebay and a 6670 on ebay) and youll be okay for light gaming for a little longer while you save for the rig you really want that im guessing you're already planning...
Yeah i'm trying to save for a better rig. I'm trying to sell an Xbox 360 and games(i never use it) for $250 and i'm probably going to get some birthday money, so my budget is kinda crap, but i'm only at 1366x768, so a budget rig will do the trick for a while.
read your sig, is the cpu dead? love those chips!, hope its some other part thats dead.
i wonder if they'd do 6ghz on ln2, phenom did....theoretically at 6ghz itll perform like an athlon x2 250 at stock
yeah i had to nag at you in SOOO many threads over like 3 months, ive just got the 9400gt back, missus is using the ddr2 (foxconn board is long gone) but still wish i had a sempy, if i find one on ebay for £5 im nabbing it!
op-
1-if your cpu isnt overheating which i doubt it is....you're fine
2-your gt210 will get hot, nvidia knows this, they put a passive cooler but its such a small die that its so low power its not meant for gaming just video and blue ray...if heating does kill it in a years time are you going to care?
3-if your gt210 is hotter than you'd like then by all means get your box fan blowing inside your pc with the fan angled so it blows slightly to the rear of the pc.
4-id recommend getting a 40-80mm 3 pin fan off something and bodging it (everyones done atleast 1 bodge job right?).
5-get world of tanks and stay in tier 1 untill you get a better rig, you'll struggle on low but at tier 1....who cares have fun :D
keep your rig as a spare or sell it to someone who doesnt need a high pc or turn it into a home theatre, just get mom to buy a 2tb hard drive and fill it with movies, your parents will love you for it.
depending on budget a 6300+m5a78l-m/usb3+r9-270 and 2x4gb of standard crucial ballistics/vengeance (not the fancy stuff) and your set for a looooong time.
as you can tell i started off poor and i still havent invested allot, just traded my way up through selling and buying parts with friends, i just bought ace combat 6 for my 360, fancied doing some retro gaming :P also got GTA5 for £15.......yeah im now selling it, it looks SOOO bad, #worsethanwatchdogs
op-
Motherboard died.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
i've already got a budget build set up and i already have the MoBo. This is what i'm going to be looking at:LINK
just been working on that, gutted
http://pcpartpicker.com/p/dGnhmG
usb3, ability to have more ram, overclocking, better cpu performance, technically the same gpu but will be cooler and quieter and have newer features and dx support etc, double the memory bandwidth. for $10 more..
$180 cpu vs $113 cpu allows you to allocate money where it can benefit you more.
you could even throw your sempy in there and do a back-to-back comparison and see how things have moved on, where they havent and become a youtuber lol
usb3, ability to have more ram, overclocking, technically the same gpu but will be cooler and quieter and have newer features and dx support etc, double the memory bandwidth. for $10 more..
You must have clicked the link in my sig rather than the one i put in the post, lulz. While i would love to have a budget like that, the $250-ish limit is all i can do for now. Hence why i'm going with the H61 board i already own. If you want a good laugh at what i'm likely to be gaming on, revisit my last post :P
eeeeee, sell the board and save for a whole new rig?
rather than corner yourself into investing in something you wont end up liking or being held back by?
740 is terrible performance for the money, you'd be better off with a ps4...
The way i see it, i'm not going to make my $30 back on an outdated, yet still $50 dollar MoBo, so i might as well use it for something. LGA 1155 is upgradeable enough if i ever wanted to put an i3 in the machine, but i imagine that i'll likely replace the entire thing when i get the money later on in life rather than doing this.
put a 3770 and second hand cheap gtx660 (only say nvidia because old ones go for peanuts as thier owners upgrade to the latest nvidia marketing) or amd if you want performance and it'll be lurrrvvvly
