1. Budget & Localisation
My Budget is about ~1500€
I am located in Austria
2. Aim
- 3D Modelling/Rendering/Animating
- Programming/complex Mathematics
- of course gaming, thinking of upgrading it later with an second GPU
3. Monitors
I am planning to run one monitor with 1920x1080
(http://www.asus.com/Monitors_Projectors/VX238H/)
4. Peripherals
I don't need any. I'll stay with my old ones
5. Case
I got the T600 White
(http://www.corsair.com/en-us/special-edition-white-graphite-series-600t-mid-tower-case)
The Rig:
Storage:
- Western Digital WD Blue 1TB
Crucial MX100 256GB
CPU:
Intel Core i5-4690, 4x 3.50GHz, boxed
CPU Cooler:
Noctua NH-D15
RAM:
- Crucial Ballistix Sport DIMM Kit 16GB, DDR3-1600
Video Card:
- ASUS GeForce GTX 780, 3GB GDDR5
Mainboard:
ASUS Sabertooth Z97 Mark 2
Monitor
ASUS VX238H, 23"
Case:
Corsair White Graphite 600T
Power:
Cooler Master V-Series V700 700W ATX 2.31
My Question is if this is going to work fine and if there were better choices.
Want to see the price list:
1 x Western Digital WD Blue 1TB, 64MB Cache, SATA 6Gb/s (WD10EZEX)
1 x Crucial MX100 256GB, 2.5", SATA 6Gb/s (CT256MX100SSD1)
1 x Intel Core i5-4690, 4x 3.50GHz, boxed (BX80646I54690)
1 x Crucial Ballistix Sport DIMM Kit 16GB, DDR3-1600, CL9-9-9-24 (BLS2CP8G3D1609DS1S00)
1 x ASUS GTX780-DC2OC-3GD5, GeForce GTX 780, 3GB GDDR5, 2x DVI, HDMI, DisplayPort (90YV04H0-M0NA00)
1 x ASUS Sabertooth Z97 Mark 2 (90MB0IS0-M0EAY0)
1 x ASUS VX238H, 23"
1 x LG Electronics GH24NS95 schwarz, SATA, retail (GH24NS95.AUAR)
1 x Noctua NH-D15
1 x Corsair Special Edition White Graphite Series 600T mit Sichtfenster (CC600TWM-WHT)
1 x Cooler Master V-Series V700 700W ATX 2.31 (RS-700-AFBA-G1)
https://linustechtips.com/topic/170300-building-my-first-rig/
1. Go with 4690K, you may have meant that....
2. Dont go with 1600mhz ram as that is quickly fading out. Go with 1866+mhz and it will cost about the same and perform faster especially for your jobs.
Everything else is fine.
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
https://linustechtips.com/topic/170300-building-my-first-rig/#findComment-2263418
you've listed this as being your priorities over gaming:
In that case i would highly recommand you jump to the core i7-4790 or 4790K if you're into overclocking, if the prices gets too steep you could look at the xeon 1230V3 wich is the same as the i7-4770 without integrated graphics (no need for that you use a GTX 780) and cost about the same as the i5-4690K...but you get hyperthreading (8 threads CPU)
The hyper-threading will help A TON in rendering, encoding, and modeling tasks...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/170300-building-my-first-rig/#findComment-2263886
2. Aim
1 x Noctua NH-D15
It's a sweet build. If the budget can take it I too would suggest an i7-4790K. The more powerful cpu will make a significant difference with 3D modeling and if the complex math solutions you program use multiple threads.
I would also suggest an IPS monitor - better color reproduction and wider viewing angles. Perhaps ASUS VX239H, 23" (90LM00F0-B02670).
https://linustechtips.com/topic/170300-building-my-first-rig/#findComment-2263971
