Total power usage
This is where I based my assumptions off. They said the card idles at 165. However the SLI post says they idle at 70w. Someone definitely got their measurements wrong.
Hardware Cannucks is measuring the full system power consumption vs just the cards i believe.
Either way you are more than able to run the setup with your current psu.
Another site is saying 590w under load, and thats with a heavily overclocked 3770k which should be more in line with what you will be looking at with your 4790k.
Edit:- Also the Hardware Cannucks is using a non reference card with higher clocks, that could also add to the discrepancy. Im also not sure what platform they tested it on, it could also be that they are using an LGA2011 system which would push it up again.
