So I just upgraded windows 8 solely for the Ultra Fast Boot feature (dw friend bought it for me as early bday present) and now it isn't letting me use it, when I try and use the Ultra Fast Boot feature it says
The VBIOS of your discrete VGA card does not support UEFI GOP, so it can not support "Ultra Fast Boot" and "CSM Diable"
I was so keen on using this feature, because my stupid splash screen takes 15 seconds (taking whole boot time to 30 seconds give or take, I know it's fast, but my friend has the same SSD and same Mobo and boots in 15 seconds flat, already tried making the splash screen timer shorter, but it didn't have any effect)
If you can help me that'd be great, I'm really gutted it doesn't work :c
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
https://linustechtips.com/topic/169099-ultra-fast-boot-problems-c/
Go into BIOS and reduce splash screen time to 3 seconds.
put it to 1 put it to 50 nothing makes a difference. I already said that I tried in OP
boot time is the only advantage over win 7 that people can give me and yet it seems to still be slow. 15 seconds to boot is about what I get on win 7 so meh.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
If the boot time is the only advantage that they can give, they really don't understand W8 .. at all.
windows 7 I averaged 30 seconds, it hasn't changed at all :c and I'm really bummed out about it. Any help?
Since your GPU does not support it, you are stuck.
Surely there is a fix? Why wouldn't a GTX 680 support it, is there anything I can do about this?
Its a known issue and there is no solution. You can get secureboot but not the ultra fast boot.
on the Asus website, it says it's windows 8 compatible, as if it doesn't work with Ultra Fast Boot, you think I could give them a ring?
It does? I had no such luck with EVGA :/
Give them a ring ~ the guys at ASUS will give you a solution or a definite answer.
Thanks for the help buddy! Will be sure to give them a ring, any idea where I can get Display Fusion for cheap and have it work on windows 8? Just a quick question :3
I don't trust the following websites but if you have a virtual credit card try your luck at
https://www.g2a.com/
https://www.allkeyshop.com/
They have some great deals.
The splash screen has nothing to do with the GPU.
Disable spash screen in the BIOS.
Slick:
I don't care if you are right or wrong... someone will come around and correct you if you are wrong. What people need to realize is that we need to step up as a community and get above the pathetic fights and bickering. Share knowledge, be friendly, enjoy your stay.
He also forgot to mention if you dont know about the topic then dont make stuff up. Dont claim fake or assume things just by reading the title, Read the post. It doesnt matter if you made 3,000 as it could be mostly crap...
please give me more then, aside from the crap that all games run better because only AAA titles are a little better SOMETIMES and older games actually struggle more.
persuade me.
it shouldn't change, you can turn off the splash screen in the bios your problem has NOTHING to do with your GPU and if it does you have a crappy motherboard. since I don't know that motherboard too well I can't help much.
persuade me.
You've definitely been misinformed, what other BS have they told you? "Games run better", I never heard that argument in a "Windows 8 vs Windows 7" discussion. :P
There are many benefits and improvements with Windows 8, but faster boot times and better game performance are at the bottom of the list for me!
Although this is not the place to argue about this, if you're interested feel free to send me a PM and I will happily tell you more about this. ^^
