It divides the frequency of the tachometer to give an accurate rpm reading.
For example, the tachometer will send 32000 pulses per minute when the fan is running at 1000rpm, so the divisor needs to be 32. If it is set at 16, it would say the fan is running at 2000rpm.
Usually it auto-selects the range, but if you think the fan is going at a different speed than what it is reporting, try changing the divisor :)
https://linustechtips.com/topic/168683-speedfan-info/#findComment-2244085
I am not entirely sure, but i am going to try.
My guess is that it means the amount of steps in the fans speed, meaning that when it is given a certain amount of voltage it will try to run at one of X amount of speeds.
It turns out i am close(ish)
CTRL+C
Fan Divisor    Minimum RPM    Maximum RPM
1        5314        1350000
2        2657         675000        default on most chips
4        1328         337500
8         664         168750
16         332         84375        not supported on most chips
32         166         42187        ""
64         83         21093        ""
128         41         10546        ""
CTRL+V
http://lm-sensors.org/svn/lm-sensors/trunk/doc/fan-divisors <<<<Source
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
https://linustechtips.com/topic/168683-speedfan-info/#findComment-2244105
