Hi Guys,
My friend commissioned me to build him a gaming PC capable of playing all the latest games, being a little bit aesthetically nice to look at, and portable(He goes to LAN events).
This is what I came up with:
http://pcpartpicker.com/user/LtRoyalShrimp/saved/xzdxFT
He plays a lot, and I mean a LOT of League of Legends, and one of the priorities was maxing out the graphics(I lol'ed at this) while keeping 60fps.
I went a tiny bit overkill, but this computer needs to last for a couple years. Mind you, he will be playing on a single 1080p monitor, and the main games are minecraft, lol, Planetside 2 and maybe some others.
So, please be respectful if you disagree with something, and if you do, please explain your reasoning, and what you would do instead.
Thanks,
-Shrimp
Gaming PC: CPU: 4770k @ 4.0Ghz GPU: Gigabyte G1 Gaming GTX 980 RAM: 16GB Corsair vengeance 1600Mhz Mobo: ASRock Extreme 9/AC PSU: Corsair AX760i Case: Corsair 750D CPU Cooler: Corsair H100i HDD: Samsung EVO 250GB, 1TB HDD, 4TB HDD
https://linustechtips.com/topic/168597-thoughts-on-build/
Hi Guys,
Thanks,
-Shrimp
Get a R9 280 instead. Its cheaper/better
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2242996
I like Nvidia GPU's(Although I use a 7970) due to easier updating and easier UI overall. My friend is not the most computer savvy person.
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2243006
The only problem for me is the case, but that is just my preference, I would go for this http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16811112348
Tek syndicate have a good video about it.
Bad link :(
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2243022
Sacrifice you're SSD and put that money into your graphics card. An SSD won't actually make you're games look better. Sure you'll have to wait a couple extra seconds here and there, but with that money you can get a 770.  Also remember you can always add one later.
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2245232
Since you said you want for it to last couple of years, i suggest that you:
- Go with K CPU
- Stronger GPU (if you're on a budget, 770/280x)
And that PSU is a little bit overkill, even if you're OC'ing...
I'd have to disagree with this. If someone is on a budget they should be avoiding K SKU Intel chips and put the additional money towards a better GPU. Games have been more GPU bound lately so it only makes sense imo
Desert Storm PC | Corsair 600T | ASUS Sabertooth 990FX AM3+ | AMD FX-8350 | MSI 7950 TFIII | 16GB Corsair Vengeance 1600 | Seasonic X650W I Samsung 840 series 500GB SSD
Mobile Devices I ASUS Zenbook UX31E I Nexus 7 (2013) I Nexus 5 32GB (red)
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2245300
But for boot, maybe ill go down 64GB? But for boot an SSD is critical these days.
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2245492
Are you not using Gaming Evolved? It does exactly the same as Geforce Experience. But I have to admit Geforce Experience has a cleaner UI.
PCPartPicker part list:
http://pcpartpicker.com/p/6GMK23
Price breakdown by merchant: http://pcpartpicker.com/p/6GMK23/by_merchant/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($214.99 @ Newegg)
CPU Cooler: Arctic Cooling Freezer 7 Pro Rev.2 45.0 CFM Fluid Dynamic Bearing CPU Cooler  ($17.99 @ Newegg)
Motherboard: MSI H97I AC Mini ITX LGA1150 Motherboard  ($108.99 @ Mac Mall)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Amazon)
Storage: PNY XLR8 120GB 2.5" Solid State Drive  ($59.00 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.92 @ Amazon)
Video Card: EVGA GeForce GTX 760 2GB Dual Superclocked ACX Video Card  ($229.99 @ Newegg)
Case: BitFenix Prodigy (White) Mini ITX Tower Case  ($79.98 @ OutletPC)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Micro Center)
Case Fan: BitFenix Spectre 97.8 CFM 230mm  Fan  ($16.10 @ Mwave)
Total: $884.94
Generated by PCPartPicker 2014-06-20 07:28 EDT-0400
The standoffs that's pre-installed in the Prodigy aren't tall enough for Hyper 212+ backplate to be intalled, so I changed it to clip-on heatsink.
I went with H97 board, because of non-K CPU, that have similar features to the Z board you selected.
Good luck!
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2248579
The OP already put Z97 Mobo and an aftermarket CPU cooler, so why can't he exactly splurge a little more for a K CPU O.o
They have the same basic performance, but K version is OC capable, which for some people is a plus...
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2249189
I agree it make a huge difference on boot. My rig takes a solid 3-4 minutes to boot. however I almost never shutdown my rig so i don't see the benefit. But that's just me personally.
https://linustechtips.com/topic/168597-thoughts-on-build/#findComment-2249906
