OK, so im helping my friend build his brother a new pc, we were thinking of getting a coolermaster elite 110 or should we get a silverstone raven?
plz note we are inexperienced builders and havent built wery many pcs.
Thanks in advance.
(pcpart picker http://pcpartpicker.com/p/3fqrYJ)
BUGET: is less then $1K (aus).
https://linustechtips.com/topic/168545-help-me-decide/
Whats the budget for a case also links would be nice :)
Yes , budget would be useful , also we would like to know what you desire : small form factor , cubic , budget , monster watercooling ( lol ) ?
Take a look at the Corsair 230T , it's nice and easy for starters
http://amzn.to/1uSeezz
http://amzn.to/1uSeqip
any of the two will fit the buget.
https://linustechtips.com/topic/168545-help-me-decide/#findComment-2259604
Any reason you are building mini ITX builds?
The are also good budget options for ATX if this is an option?
What parts you using for the build as this would also help people recommend cases to you as anything such as the GPU is a factor also to consider?
for a little kid and it will fit on the desk better. build: http://pcpartpicker.com/p/3fqrYJ the cooler master case is in there but i think the raven also looks cool.
https://linustechtips.com/topic/168545-help-me-decide/#findComment-2265477
