Will downclocking memory clock help cool GPU?
Go to solution Solved by Lays,
75c is perfectly fine, and extremely acceptable.
My GPU runs at like 75oc when gaming, will lowering the mem clock from say 1500mhz to 1450 help cool it abit?
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/168427-will-downclocking-memory-clock-help-cool-gpu/
No, but lowering the GPU clock and GPU voltage will.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
The core clock is usually the main contributor of the heat so it wouldn't be noticeable or worth the drop.
You gotta do you girl. I always say you gotta do you. And if he's doing him, then who's doing you? Because right now, it seems like no one's doing you.
- Stefani Stilton (she / her) 🏳️‍🌈🏳️‍⚧️
ah that's the thing it's not at all overclocked, all at stock, can't even move core voltage (locked)
ok thanks guys
