I apologize in advance for my english.
I am trying to build my second PC. First one I build like LEGOs I had all parts,I just put them all together and this one I am trying to build from scratch. I already know I want GTX 780 ti and NZXT H440 Razer Edition. So I would like to ask you what my other parts should be? And I would like to point out that I am only looking for performance I don't really care about matching colors AND one last and the most important thing is I am not going to be overclocking CPU or GPU so I don't really need overkill Mobo or custome liquid cooling. Thank you in advance. :)
https://linustechtips.com/topic/167550-help/
Budget?
Use?
Peripherals?
Monitor?
I probably won't get back since it's 2AM, but for other people this is good.
/off topic
14 hours difference!!!!!
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/167550-help/#findComment-2229182
Monitor-BenQ XL2420Z, 24"
I will be using it mostly for gaming
Peripherals- Astro A40 Audio System, SteelSeries Apex and Corsair Vengeance M65
My budget for this build is around 1500-2000 €
Do you have the peripherals already? or should i include them in the price of the build?
PS how old r u?
Samung Tab S 8.4
https://linustechtips.com/topic/167550-help/#findComment-2229258
I am doing a partpicker now, you live in Germany (euros?)
H440 doesn't seem to be available in Germany, Razer edition or otherwise. Are you getting the same?
"Maybourne, you are an idiot every day of the week; why couldn't you have just taken one day off?!" —Samantha Carter
https://linustechtips.com/topic/167550-help/#findComment-2229271
If you can wait a little longer I would recommend getting the i5 4690k when it comes out later this month (not definite date but most likely this month). For the meanwhile you can order most things except the CPU. That is if you wish to overclock at some point.
https://linustechtips.com/topic/167550-help/#findComment-2229291
PCPartPicker part list: http://de.pcpartpicker.com/p/cscmFT
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  (€273.72 @ Amazon Deutschland)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€33.40 @ Amazon Deutschland)
Motherboard: ASRock Z87 Pro3 ATX LGA1150 Motherboard  (€77.40 @ Amazon Deutschland)
Memory: Kingston HyperX Grey 8GB (2 x 4GB) DDR3-1600 Memory  (€68.98 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€50.39 @ Pixmania DE)
Video Card: Zotac GeForce GTX 780 Ti 3GB OC Video Card  (€629.76 @ Amazon Deutschland)
Case: BitFenix Shinobi ATX Mid Tower Case  (€11.90 @ Caseking)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  (€15.83 @ Amazon Deutschland)
Total: €1659.14
Generated by PCPartPicker 2014-06-17 11:58 CEST+0200
https://linustechtips.com/topic/167550-help/#findComment-2229355
Evo updateovao sam da imas SSD, cjene iz njemacke. (UPDATE #1)
PCPartPicker part list: http://de.pcpartpicker.com/p/JrxtK8
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  (€54.27 @ Amazon Deutschland)
Total: €1845.41
Generated by PCPartPicker 2014-06-17 12:02 CEST+0200
https://linustechtips.com/topic/167550-help/#findComment-2229371
