My Current PC has:
Intel Core i5 4670k @ 3.8 GHz, can go up to 4.5 GHz but the heat in my room was overwhelming
EVGA Geforce GTX 650ti Boost
8 gb Corsair Vengeance RAM
Corsair H100i
Corsair CX600 PSU
Gigabyte GA-Z87X-UD3H
WD Caviar Blue 1tb
Fractal Design Define R4
Upgrades I want to Make:
Corsair AX760/860
Samsung 840 Evo/Pro 240gb
Corsair 760t
16 GB Corsair vengeance/ Kingston HyperX RAM
My question is, I am selling my iPad Air for $400 and I want to get either the GTX 770/780. I do not know whether I should save $100-$200 and get the 780, or if I should get the 770 right off the bat. What is the performance increase between the two? Thank you!
https://linustechtips.com/topic/166946-help-upgrading-pc/
R9 290 is right at your pricepoint and performs better than 770 and same as 780. PowerColor PCS+ R9 290 is really great at $410
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/166946-help-upgrading-pc/#findComment-2221634
1. Look at benchmarks.
2. Get a ssd.
https://linustechtips.com/topic/166946-help-upgrading-pc/#findComment-2221639
Im going to stick with nVidia because A AMD has compatibility issues and B  Im kind of a nVidia fanboy
compatibility issues lol
be a fanboy all you want, all you're doing is missing out on money lol
https://linustechtips.com/topic/166946-help-upgrading-pc/#findComment-2221686
Exhibit A:
Watch_Dogs
If you buy stuff at microcenter the people there will give you watchdogs and daylight for free
plus AMD comes with three free games worth up to $150
https://linustechtips.com/topic/166946-help-upgrading-pc/#findComment-2221816
