Define R4 and H100i?
Solved by lani100,
Hey Guys,
I'm currently looking forward to upgrading my case.
I really do like the Fractal Design Define R4 and I also want to get a water cooler, I'm having the Corsair H100i in mind.
So but my question is whether this will fit in with an Asus P8Z77-V LK.
If there are aleady answers to this question, I'm sorry that I did not find them.
Looking forward to your answers!
Yes this will fit i have a Gigabyte z87x-d3h and that has a large heatsink and even that fits.
So it should be no problem for you.
Make sure to pick up some quiet fans for your h100i because the stock ones tend to be a bit on the loud side.
