hard drive help
Go to solution Solved by 79wjd,
windows xp: start>run>msconfig>startup>uncheck anything unnecessary>restart.
windows 7: start>system configuration>startup>uncheck anything unnecssary>restart.
That will stop all that crap from running on start up.
P.s. do make sure you know what each item is before disabling it.
I am reaching out for help for my computer because i am sick and tired of random stuff like anti virus scans and stuff like that popping up on my computer everytime I reboot. Would it help it I got a new hard drive and re-downloaded the games and programs I want? I only want to be able to play my computer without it being slow. i have a 1tb hard drive now and only used like 200gb so far.... it cant be that i have to much but because I have stupid programs that wont leave me alone. i wanted to get a bigger hard drive anyways can anyone help?
https://linustechtips.com/topic/166061-hard-drive-help/
Disable them.
Anti virus in 2014 is crap. It doesn't stop jack these days.
Remove programs you don't need.
Disable programs from turning on at startup (Start bar > Run > MSConfig > Startup)
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/166061-hard-drive-help/#findComment-2210236
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/166061-hard-drive-help/#findComment-2210238
