USB & Micro USB Cable Terminals
I'd like to start making my own sleeved USB cables from scratch, but I can't seem to find a site selling the terminal ends and their plastic covers, especially with Micro USB connectors. Is there a site I'm missing that's right under my nose? I feel that's the case. I'd like new parts so I'm not cutting up different pieces and gluing them back together. Thanks.
Type A Male USB http://www.dhgate.com/product/new-10pcs-type-a-male-usb-4-pin-plug-socket/181334028.html#sa1-2-1|770521985
More
http://www.digikey.com/product-detail/en/1001-027-BL-01000/1175-1012-ND/3064743
http://www.aliexpress.com/usb-plastic-housing_price.html
Bare USB cable
http://www.alibaba.com/product-detail/USB-wire-USB-cable-USB-printer_289352033.html
That was just a quick look up, there are many sites that sale stuff like that , you will have to do reasearch though to see what is best for you. Hope that helps you get started.
