R9 290 Reference Model worth?
Go to solution Solved by Zelx,
They're shipping me the Gigabyte version for less 10€ than the reference model, not really a big fan (ah!) of gigabyte version, but I will end up saving about 30/40€. (and MSI would take a month to arrive, and tbh this store is playing with me long enough).
EDIT: Actually they have one last gigabyte on stock, maybe will arrive today :) worth
Sooo I ordered my computer from a local store, and they mailed my saying they got the reference model (after making me wait for weeks) by mistake and if I want that one or wait for the MSI model to arrive...is it worth to get the reference model or just wait?
Thanks! :/
Don't get a reference model. They are loud and they are tiny combustion engines. Waiting is 9001% worth it.
mounting them really close together in a small case.
even then the temperatures get off the charts... at that point might as well get an xfx card which is completely flat on the bottom and does not interfere with close cards.
sudo chmod -R 000 /*
AMD's reference coolers are crappy, no effort has gone into them.  It's like their heads are back in 2009 when the 5870 was the coolest thing on the planet.  Sorry AMD, your cards are frickin hot now.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
please, please wait.  The refrence card is like a plane taking off and it burns like hell, litterally.  Unless you plan to watercool the refrence design is useless imo.
They should change their name to AFT (Ain't give no F*cks about Thermals). I realize that this is a shitty abbreviation. :P I'll crawl back under my rock now.
Bert & Ernie before squirting spermie.
