Hello, guys,
In my company's computer, I am experiencing slow reaction whenever I open up Quickbook. Maybe I know what's the deciding factor in running Quickbook? Like If I add more ram, would it be faster? Or I need to replace the CPU?
Window 7 64bit
i3-2100 @3.1 ghz
6GB ram
https://linustechtips.com/topic/165410-quickbook-problem/
Hello, guys,
Window 7 64bit
i3-2100 @3.1 ghz
6GB ram
I don't know what the system requirements for Quickbooks are.  That said, it might be that the computer has a slow HDD and it is taking a while for the data files to be read in.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/165410-quickbook-problem/#findComment-2201414
Alright. I think that might be the problem as well. Actually our quickbook is linked to a server. Maybe we should upgrade that server's computer so everyone in the office can actually run the quickbook quicker.
https://linustechtips.com/topic/165410-quickbook-problem/#findComment-2201527
If the server is the machine that runs the software, the specs of the server and the network will likely have a bigger impact then the client machine.  That's probably why the client machine is realtively low spec.  The server is doing most of the actual work.
https://linustechtips.com/topic/165410-quickbook-problem/#findComment-2201839
