Hey guys, I just started to transplant my current setup into my Enthoo Primo today, it come with 5 140mm fans that have almost the same, air flow and static pressure ratings as my aerocool shark devils, just that the ones that come with the case run at max 1200rpm and mine run at 1500rpm, so considering that the ratings are the same, do you think it would matter where they go??
https://linustechtips.com/topic/165315-case-fan-questions/
Less RPM = less noise, just make sure they're facing in the right direction.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/165315-case-fan-questions/#findComment-2199940
