Getting surprisingly high temps running my 3930k stock and lower voltage. What could the problem be?  Coolgate 480mm Radiator with a phobya  uc-2 block. I have flushed out my loop twice and cleaned the block with no luck.  Would i need to try a different block for it?
post-21725-0-04839800-1402561605_thumb.j
post-21725-0-09604500-1402561611_thumb.p
     Phanteks Enthoo Primo Intel Core i7 3930k | Asus Rampage iv Formula | Seagate 4TB
Dual 480mm Coolgate + 240mm Coolgate | 16GB G.Skill Trident X F3-2400 OCZ ZX 1250W
      4GB Asus GTX 670 OC 3 Way Sli Western Digital 2TB | Samsung 830 128GB Raid 0
https://linustechtips.com/topic/165256-3930k-overheating/
What's complete loop`? 66 °C is a bit warm for such a cooling setup. Also what fans do you have and what's your ambient temperature?
Ambient temp is around 20c, i got 6 silverstone ap 121's running at medium to high speed. I use to have my 3 video cards in the same loop but i decided to put them separate to make sure it wasnt them making it overheat.
480mm Coolgate Copper Tube 480mm Radiator
Phobya DC12-220 12V Pump
Phobya 5.25in Bay Reservoir Black
EK Ekoolant Blood Red Premix 1000mL Coolant
Here is a idle temp http://puu.sh/9q1Tu/430caff964.png
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2199191
is the thermal paste still good? Maybe that is an issue?
Computer Specifications:
AMD Ryzen 5 3600  Gigabyte B550M Aorus Elite | ADATA XPG SPECTRIX D50 32 GB 3600 MHz | Asus RTX 3060 KO Edition CoolerMaster Silencio S400 Klevv Cras C700 M.2 SSD 256GB
1TB Crucial MX500 | 1 TB SanDisk SSD Corsair RM650W
Camera Equipment:
Camera Bodies:
Olympus Pen-F Panasonic GH3 (Retired)
Lenses:
Sigma 30mm F1.4 | Sigma 16mm F1.4 | Sigma 19mm F2.8 | Laowa 17mm F1.8 | Olympus 45mm F1.8 | Panasonic 14mm F2.5
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2199207
tried 2 different thermal pastes with many spreading methods, no difference.
http://puu.sh/9q2qk/524be0ac98.png Could it be a cpu fault or something to do with the loop, eg: pump or block
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2199211
prolly an air bubble stuck in the CPU block. the direction indicates the exit is at
the bottom and the inlet is in the center. and what's left is the pocket of air above
the inlet that will not exit as air does not travel down to well.rotate CPU block 180°
and rebleed.
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2200161
and rebleed.
Rotated the block back to its up right rotation and still getting hot, ive been trying to drain all the bubbles out of the loop. still high temps as of this time.
i use to have a h100i on it and that was getting hotter so i swapped it out, could it be the cpu itself not having the thermal paste between the dye and the heat spreader right?
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2204873
@Anfroney
the LGA2011 i7 CPUs are all soldered die to IHS, so it is not like the ivy/haswell
issue of ill-applied TIM.
stock clock, warmer temperatures both with H100i and custom loop. 66° A=20°
3 fans on the 480? 8-pin EPS fouling the lower fan? got any stouter fans for testing?
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2204955
@Anfroney
i got 6 fans on the 480mm rad, 4 in pull and 2 in push, i couldnt add 2 more to pull cause of hdd's in 5 inch bays and the 90 degree fitting.  i could proibably try to move the fitting out more to fir a 7th fan. here is photo of top fans http://puu.sh/9rkWi/6cd63ac0fa.jpg
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2204973
fixed up the temps issue,  had to change the setup of my loop. use to be  Res Pump Rad Cpu,  Now it is Res Pump Cpu Rad.  temps maxing at 46c stock clock. time for some nasty overclocks :)
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2229574
I'm still going to say that you dislodged an air bubble, because sequence makes little to no difference to temps.
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2229821
i took loop apart before and cleaned everything and tried it in the rad than cpu config, temps where still high,  im guessing the pump doesn't have alot of pressure behind it or the cpu block has a dense water channel.
Atm ive run prime 95 for 2 hrs or so with CPU at 1.3volts and 4.375 ghz.  http://puu.sh/9xopt/af312b6f8b.png
Didn't feel like much water was passing loop in old setup.
https://linustechtips.com/topic/165256-3930k-overheating/#findComment-2229914
