Anyone having problems installing the new iTunes to a windows 7 PC? I haven't had a problem with this before this newest version came out. Anybody? I can give further info if needed.
Are you using the apple application update program or are you downloading it on a browser and installing it manually?
https://linustechtips.com/topic/165211-itunes-problems/#findComment-2198744
