I dont think it is that important. but im not 100% sure
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-187834
Im sure the most it will affect is the cooling potential of the specific block, obviously copper would have better thermals, ect.
I dont think oxidization is really that big of an issue as long as you get good quality components.
I'm just a soul who is up to no good.
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-187855
^This. Also, nickel blocks are not actually made of pure nickel. They are just copper blocks with nickel plating. This won't affect cooling performance. The nickel plating is just their for aesthetics and as a corrosion inhibitor.
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-187963
There is some concern with having silver in a loop with nickel plating, but copper,nickel and brass are OK. If you use a commercial coolant they will have the proper anti corrosive additives as a safe guard. Aluminium should never come into contact with your coolant..now a days most water cooling kit is aluminium free.
Your best effort is the easiest thing to give to someone else..
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-188241
Nickel and chrome prevents the galvanic corrosion between copper and silver. It was a myth started by EK to cover up some of their blocks that had substandard nickel plating which chipped off and exposed the copper underneath to the silver kill coils.
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-188364
..guess that is why both EK and Koolance void their warranties when silver kill coils are used with their products..?
Covering their asses just in case of a repeat on substandard plating. Every other water block manufacturer that uses nickel plating does not prohibit you.
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-188474
No..not every one will..but the main issue is still..using silver in the loop..when it really does not need to be used.Go ahead and use nickel plated components ..just be advised that adding silver to the loop may cause problems..
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-188675
Nickel is >>>>>>>>>>>>>>>>>>>>> copper guff
If you get waterblocks that show copper externally you may as well order some damn brasso and spend every day polishing it to oblivion.
/rant
In case someone didn't know what he is complaining about: Copper oxidizes in air and turns green after prolonged exposure.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-190326
This.
My raging rant made it unclear.
I have 680 lightnings for which only 2 blocks were made - EK circle yuks or aquacomputer aquagrfx. The aquagrfx is full copper with stainless steel plating. When I got them they were ultra shiny copper. Now they are a very dull dirty brown.
The inside was still fine last I check, but I don't really care about how the inside of the block looks.
Wish I'd got different cards.. or aquacomputer had made a nickel plated version :(
https://linustechtips.com/topic/16507-material-for-waterblocks/#findComment-190350
