Do you think custom water cooling will become a thing of the past now with the brackets for gpus and the closed loop coolers they have out there
do u think less people will do it
no, the brackets are usually a "thing" till issues, compatibility or just sick of looking
at miles of black skinny hose. then most migrate to a custom loop as they get more
familiar to what water cooling can achieve or obtain.
AIO cooling can be a solution to better thermal options over some air solutions. is it
"custom" water cooling? nope. it can be cheaper, but cheaper isn't always the "best"
route to travel, unless budget restrictions dictate otherwise. it is a PITA to use the
Corsair HG-10/NZXT G-10 on a dual GPU build with the CPU bound up in its own AIO.
https://linustechtips.com/topic/165021-custom-water-cooling/#findComment-2198614
Custom Water Cooling is hobby....wayyyyyy too many enthusiasts are simply "into it", !!!!
3930K - 4.85Ghz w EK Supremacy | RIVE w Photon 170 D5 Vario / Res Combo | 16GB 1866 Doms | Evga GTX 780Ti SC SLi w EK Full WB's| AX 1.2 kW | 900D - 1 x RX480 1 x EX360 & 1 x EX240 Rads w Noctua NF F & Corsair SP "Push" | W7 HP x64 | MK11: P25,113 http://www.3dmark.com/3dm11/7499603 | Firestrike: 19,576 http://www.3dmark.com/fs/1177627
https://linustechtips.com/topic/165021-custom-water-cooling/#findComment-2198717
