You should be able to but also a resistor will do the job just fine.
An inline fan reducer may work. But I have no idea what value they are but they are a good high wattage resistors. If you have one around give it a go.
If its too dim then you need a lower value resistor.
i7 5820k, Asus X99 Pro, 16GB Muskin Blackline, EVGA GTX 980, Corsair Air 540, Samsung SM951 256GB M.2, Samsung 830 256GB, Seagate 3TB, Ducky shine 4 MX clear & brown, Logitech G700s, Asus PB278q
https://linustechtips.com/topic/165004-help-led-controller/#findComment-2198999
