Hey guys, my friend and I just build a new computer
Specs: 780ti, 3x coolermaster blue LED fans, 650w gold psu, z77 g43 mobo, i7 2600 cpu, corsair 760t.
It all works perfectly fine, however it is VERY loud. I was wondering if there is way to turn down the fan speed, i've tried using "control centre" and "FanSpeed" but i dont have the option to change the speeds.
Also im pretty certain it isn't the CPU cooler, as i've reused it from my old computer and it never fan this loud  before.
It would be great if anyone could help, thanks
https://linustechtips.com/topic/164821-fans-too-loud/
Best way is to get a fan controller. If they're not PWM fans, they're going to be running at 12v all the time.
Well my case does have a one button fan controller, but it doesn't seem to do anything, according to SppedFan4.49 fan 1 & 2 are running at around 6.5kRPM - http://puu.sh/9oHj4/44c4a4bed3.png
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193385
Have you made sure you've connected the fans to the controller? If they're plugged into the motherboard, the controller won't do anything.
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193410
Well im pretty sure they are connected, as when i do press the button the LEDs give off less light, it's just still saying at the same noise level,
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193415
Seems like it's not the case fans then. Are you using the stock CPU cooler? That can be pretty loud too. It could just be that the fans you have are generally loud though, but the fan controller should make a difference with the noise.
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193429
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193436
Yes i am using the stock CPU cooler, but i didn't think it could be that, as it was never this loud before
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193439
The only suggestion I would have then is to get a dedicated fan controller to have more control over the fans. Unless you have something like a Sabertooth board that uses those tiny fans, I can't think of anything that would make so much noise. The graphics card shouldn't be an issue, even the stock cooler is pretty quiet.
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193457
Ok, i will definitly look into getting one, however on every guide i look for with speed fan, they have the option to change there speeds, is there a reason i can't?
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193463
I'm not familiar with SpeedFan, so I'm not sure if there's a particular reason.
If you have them connected to the fan controller, you won't be able to control them with software though. SpeedFan should only be able to control those connected to the motherboard.
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193474
ahh ok, thanks for the feed back
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2193485
just dont unplug the CPU one:) its a bad idea
You can, just long enough to identify if thats the one making the noise
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/164821-fans-too-loud/#findComment-2195877
