Hi guys!
I need to do an essay about nanotechnology and since Linus changed me into a computergeek, I thought I would make something about computers. My idea was to talk about the latest changes on data storage but specifically on hard drives, SSD's and about spintronics in the future.
Could you guys help me to understand how they work?
With the hard drives, I understand that it uses little magnetic fields to determine whether it's a zero or a one. But how does the needle change the magnetic field exactly? And which states equals a zero or a one?
I've read once on a site, that SSD's are already making use of quantum mechanics, is this true? A sort of tunnelling effect I remembered.
Thank you for the help :-)
https://linustechtips.com/topic/16468-how-does-data-storage-work/
The needle, if I remember right either deposits or removes electrons.
SSDs currently are just flash memory, I think the quantum computing side of things is all theoretical/experimental (the sort of thing being done by universities) I'm pretty sure that's still prohibitively expensive for mass production.
You could probably get much more concise explanations off of wikipedia (and with citations at the bottom)
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/16468-how-does-data-storage-work/#findComment-187236
The hard drive changes the area to a positive or negative, thereby equaling a one(positive) or zero(negative). A computer chip then interprets the data and converts it into binary code. Hard disk platters are coated in a very very thin magnetic film, which makes them magnetic. You might find this helpful.http://computer.howstuffworks.com/hard-disk.htm
Also, no SSDs don't use quantum mechanics. It's just transistors switching on and off. (changing the "position" to represent your data)
https://linustechtips.com/topic/16468-how-does-data-storage-work/#findComment-187248
moved to storage area
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/16468-how-does-data-storage-work/#findComment-187437
