It should work just fine. I personally have had issues with blue screening whenever I put certain hard drives in certain older computers. I'd say you may as well try because what do you lose, the 30 seconds it takes to plug in the sata connector?
RIP in pepperonis m8s
https://linustechtips.com/topic/164622-hard-drive-swap/#findComment-2190487
