I was messing around and somehow it started a new work queue that runs on my GPU. I have one that is 93.44% done and it trys to start the new one everytime i start folding. How can i remove this new one that is not even started.
https://linustechtips.com/topic/16462-how-to-remove-a-work-queue/
Two options. First, try a reboot. Second, let it go. May take a day or so, but should clear itself out. I see this occasionally.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/16462-how-to-remove-a-work-queue/#findComment-187504
Does it get a new WU when you start folding or when a WU reaches 94%.
Its normal for the client to download a new WU when a WU is 99%(default value) complete and its fine if it reads "Ready" so you have nothing to worry about.
Do you have the "next-unit-percentage" added to a slot?
https://linustechtips.com/topic/16462-how-to-remove-a-work-queue/#findComment-187604
No clue what ur talking about. I tried to add my hd 400 graphics to a slot and it downloaded a work unit and it wont start now that the GPU has finished the 90% one.
https://linustechtips.com/topic/16462-how-to-remove-a-work-queue/#findComment-188073
Fixed it guys i just removed the GPU form the slot and it removed the WU and downloaded a new one.
https://linustechtips.com/topic/16462-how-to-remove-a-work-queue/#findComment-188077
Good to hear - and yes, no HD4000 for you! :)
https://linustechtips.com/topic/16462-how-to-remove-a-work-queue/#findComment-189923
