Hey folks,
i have this GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125466&cm_re=gtx_760-_-14-125-466-_-Product, gigabyte gtx 760 windforce.
and i have this temps on idle:
i get 40C, and ambient temps are like 30C, i live in chihuahua,chihuahua mexico,
and is hot, i think the highest in the city are like 42C or 45C, but in my house are like 30C - 32C
with the air conditioner is like 27C - 25C.
So are this temps of GPU are ok??
and full load are like 80C if you want to ask full.
Thanks in advance
PC Specs: Case Corsair Vengeance C70 - CPU i7-4770K @3.5Ghz - MOBO Gigabyte Z87X-UD3H - RAM HyperX Fury 2x8GB @1600Mhz - GPU MSI VENTUS RTX 2080 SUPER - HDD Seagate Barracuda ST1000DM003 1TB, Toshiba DT01ACA100 1TB, WD Black 4TB - PSU EVGA 750 G2 - Display Samsung S22C150 - CPU Cooler CM 212 Hyper EVO - Mouse Steelseries Sensei 310 - Current Wattage by pcpartpicker: 387W.
https://linustechtips.com/topic/163775-gpu-temps-are-ok/
Seems okay enough to me. The load is a little bit high for my liking, but it will live.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/163775-gpu-temps-are-ok/#findComment-2178964
Anything under 85C is safe.
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/163775-gpu-temps-are-ok/#findComment-2178966
yeah seeing that your ambient temps are that high, your gpu temps are good
CPU: i7 4770k  Motherboard: MSI Z87-G43 SSD: ADATA 250GB PNY 120gb HDD:2xSeagate 2TB (One is an external HDD) GPU: RTX 2070 Super RAM: 16gb Corsair Vengeance 1600 PSU:Corsair CX-M600w Case: NZXT Phantom 410
https://linustechtips.com/topic/163775-gpu-temps-are-ok/#findComment-2179057
Full load temp is high but safe, your ambient is brutal so that's to be expected, no problem with the card.
Actually fairly impressive considering it's Gigabyte and it's Chihuahua.
Im going to make a update later in winter, to see what is going to get the GPU in cold days, cuz here can be very cold, in the city the lowest are -10C - 0C, normal like 4C - 6C, in my house like 15C - 23C
https://linustechtips.com/topic/163775-gpu-temps-are-ok/#findComment-2179338
That's like spring weather in Chicago lol
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/163775-gpu-temps-are-ok/#findComment-2179347
