Help me to fix it
Solved by Timme,
19 minutes ago, Nikol Sahoo.. said:nope 1 year old and i was just updating intel graphics oem driver
Happen to have a recent recovery point or image? If this only occurred after the updates(and no other OS tinkering, right?), it might as well be one of those. Try booting into Safe Mode with Networking. It should load the very minimum on the network side of things - if there are no problems, the new drivers are the problem.
Also, do you have the latest BIOS version?
