Can I get some help?
Go to solution Solved by xAcid9,
6 minutes ago, Foure said:
unless i did this wrong it didnt work
Can you share the output of
cat /proc/cmdline
and
nvidia-smi
Hello internet foure here,
I am switching my gaming pc from Windows 10 to Nobara Linux, and am having Nvidia driver problems. Nobara installs properly, but always leaves me with a 4:3 aspect ratio, which I assume is a driver problem, so I uninstall all Linux Drivers for my Nvidia GPU, reboot, and install the correct driver because Nobara does not support my Current GPU, reboot, and still have the same problem. What do I need to fix this problem?
Thanks, foure
Specs
AMD FX-6300 6-core
Nvidia Geforce 1050 TI
16 GB DDR3
Driver: 580.159.03
Nobara Linux 7.0.5/7.0.1
https://linustechtips.com/topic/1637183-can-i-get-some-help/
you need to uninstall the proprietary drivers most likely and install nuveau
                   -`                    y0ur5h4d0w@Darkness
                  .o+`                   -------------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: Darkness
               `+oooooo:                 Kernel: Latest
               -+oooooo+:                Packages: Only what i need to keep it simple
             `/:-:++oooo+:               Shell: ZSH
            `/++++/+++++++:              Main Monitor: LG Ultragear LG 27GS85Q
           `/++++++++++++++:             Secondary Monitor: Asus MG28UQ
          `/+++ooooooooooooo/`           DE: Plasma Always Bleeding Edge
         ./ooosssso++osssssso+`          WM: kwin
        .oossssso-````/ossssss+`         Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       -osssssso.      :ssssssso.        Icons: Breeze-dark [GTK2/3]
      :osssssss/        osssso+++.       Terminal: Kitty
     /ossssssss/        +ssssooo/-       Terminal Font: Noto Color Emoji 17 FreeMono 13
   `/ossssso+/:-        -:/+osssso+-     CPU: AMD Ryzen 7 9800X3D (16) @ 5.307GHz
  `+sso+:-`                 `.-/+oso:    GPU: AMD ATI Radeon RX 7800 XT
 `++:.                           `-/+/   GPU: AMD ATI Radeon Graphics
 .`                                 `/   Memory: 61830MiB
https://linustechtips.com/topic/1637183-can-i-get-some-help/#findComment-16897136
Posted (edited)
I have uninstalled the proprietary drivers, and Nobara autoinstalls nuveau, which, when running it, I get 1 frame per sometimes.
Edited by Foure
https://linustechtips.com/topic/1637183-can-i-get-some-help/#findComment-16897144
42 minutes ago, Foure said:
Driver: 580.159.03
IIRC that's the correct driver, try add nvidia-drm.modeset=1 to the kernel parameter on boot menu.
https://linustechtips.com/topic/1637183-can-i-get-some-help/#findComment-16897148
cat /proc/cmdline
and
nvidia-smi
https://linustechtips.com/topic/1637183-can-i-get-some-help/#findComment-16897152
Posted (edited)
Fixed It!
I ran nvidia-smi, and it responded, not knowing what where the driver files it was looking for were, so I reinstalled the driver, and, turns out, the driver did not install the first time, even though it said it did when I installed it the first time. Thank you all for your hard work; it is very much appreciated.
foure
Edited by Foure
https://linustechtips.com/topic/1637183-can-i-get-some-help/#findComment-16897153
