Help on upgrade path
48 minutes ago, Patrick98 said:
my tought process on why i want to upgrade to B550 (not specific to asrock pg riptide) and to R5 5600x is because of Pcie 4.0. I read that starting from RTX 3000 series GPU use pcie 4.0, some only use x8 even, thats why i want to upgrade my current Mobo since A520 and R5 4500 only support Pcie 3.0. hence the step is mobo -> cpu -> gpu not GPU first.
So from here, i guess. Rather than upgrade the mobo first. Should start from GPU then CPU and lastly mobo?
Pcie4 is basically useless outside of fast storage which in and of itself is already quite useless for games beyond gen3 speeds so dont waste the 1.5-1.something jt on some b550 you wont even see any benifit from
Also you are going to replace the r5 4500 anyways so no need to consider it, btw it resells for around 800 900rb far as i can tell on fbm/tokped so thats like half the cost of a 5600 covered
Any complaints with your current board like i/o wise? Say too little usb a ports or the single nvme slot, cause ngl the only valid reason to swap your board if you have no complaints would be to "downgrade" it and get some extra cash
Putting it in quotes as a520 and b450 are basically the same thing and you can find midranger b450 like the A pro max, pro4, etc. For as low as 700rb ish used and that a520 itx board may sell for around 1.2-1.5jt used, though youd only do this if you want to speed up your upgrade or want some extra cash for any other reason
4 hours ago, Patrick98 said:AMD R5 5600X
And dont waste your money on the x version since the 5600 non x is basically the same thing with slightly lower clocks, Heres one on tokped for 1.8
If you were thinking of This 5600x yeah im pretty sure thats some sort of scam, check the stores statistics and you see 1000+ produk with no rating and they only started selling earlier this year, if you want to give it a shot you could and probably with a good bit of safety at that since tokped has good customer protections but ngl i wouldnt waste my time with this
4 hours ago, Patrick98 said:IDK what should i buy. (something that can run comfortably at 1440p 60fps high overall setting on 32" monitor)
I swear the 6800xt used to be more expensive than the 3080s (like 5jt ish)
Anyways a gentle reminder that if you want to buy new lowk kabur ke malaysia sehari 2hari and buy there cause new prices here suck beans probably due to the horrific import taxes like wdym rtx 5060 is 400$
The only valid gpu choices here that wont suck your wallet dry and give you actually good performance for your money are used rx 6000 and rtx 3000 for the most part and seemingly some of the higher end gpus like this 9070 right at 10.3jt as the rtx 5060 and rx 9060xt are a complete joke pricewise, oh and dont bother with the 9070gre doesnt save you that much money and seems to be a good bit worse + garbage reaper model that has terrible temperatures (ie thing will likely get more noisy due to bad cooler design)
4 hours ago, Patrick98 said:2. Add one more 1080p monitor for second screen (do i actually need this since i don't stream, just record)
Maybe something like This?
If you arent sure if you need it i guess you could also just reuse an old monitor or buy some cheap one for 200 300rb like This or a slightly fancier one like This so in the case you dont actually find any use out of a secondary monitor you arent out 1jt
