So last night we were having one of our normal afternnoon storms here in Florida and our power went out for a split second. I came back into the office and saw that both of my monitors were flashing, I thought it was abnormal so I went ahead and rebooted my system and it did the same thing. At this point I was at a loss. I went ahead and unplugged all of my peripherals except for my keyboard, mouse, one monitor and my GPU, it kept giving me the same error, so at a last resort, I went ahead and did a system restore to an earlier backup and that seemed to have solved my issue's, it booted within its normal times with my SSD. My question is, should I be worried at all that there is a larger error and I have just managed to put a band-aid on it? I am fairly sure it is not my PSU, Mobo or GPU seeing as I am fairly sure that I would not have managed to operate normally after I did my restore. Thanks!!
“Do not go where the path may lead, go instead where there is no path and leave a trail.” -Ralph Waldo Emerson
https://linustechtips.com/topic/163569-power-failure/
Well if it is running fine then you should be fine, the powercut probably messed up some system files and nothing else. The flashing monitor I have no idea on so can't help you there.
Thought keep an eye on it if anything starts behaving weird.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/163569-power-failure/#findComment-2176128
I am watching this PC like a hawk right now
https://linustechtips.com/topic/163569-power-failure/#findComment-2176369
Does anything seem to be out of the ordinary?
https://linustechtips.com/topic/163569-power-failure/#findComment-2176532
run a few benchmarks. play some games. push the system and look for anything that could be an issue.
Just be thankful it didnt kill a component right then and there, and you should get a power bar with surge protection on it.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/163569-power-failure/#findComment-2178928
