Need help comparing two microSD cards...
Solved by DoctorNick,
3 hours ago, r00tb33r said:64GB models...
This:
https://www.amazon.com/dp/B08WZDWYFG
Versus this:
https://www.amazon.com/dp/B08G81XVW4
I have both, but I seem to be hitting the speed limit of my USB adapter, I'm getting similar read and write speeds on both.
What are some other easy/accessible ways for me to benchmark these cards? Something with minimum setup to run tests.
I intend to use them in a DAP, and possibly a Raspberry Pi (model 3B+).
Yes A2 is good for Rpi
