Hey guys!
Recently I've bought a new case, which is the Husky Dome 700 (https://www.kabum.com.br/produto/619686/gabinete-gamer-husky-dome-700-7-fans-argb-vidro-temperado-frontal-lateral-water-cooler-360mm-atx-m-atx-usb-3-0-hgn700pt) which comes pre-attached with 7 fans (2 sets of 360 and 1 120 in the back). Along with said fans it also comes with a hub which works for both ARGB and Fan control.
All of the default fans are to the hub by default and the only cables I connected to it were for the air cooler of the CPU, I then connected the PWM cable (4pin) from the HUB to my MB and for some reason the fans are doing a "Breathing" motion and I cannot edit the curve through either software or the BIOS, do you guys have any suggestion on how to fix this? The ramping sound of fans is hella bothering me and the temps don't seem to be improving due to this
Thank you guys
https://linustechtips.com/topic/1635510-help-with-case/
there need to be an argb cable 3pin to mb. some case have a argb controller built in and have a button on the case. might need to push a button to switch to mb sync
https://linustechtips.com/topic/1635510-help-with-case/#findComment-16886974
Perfect! I'll have a look but from what I can see, I see no such 3pin cable or a button to switch between these two, for clarity I have a ASRock B450M Steel Legend, I looked through the manual and I connected to the right top most pin slot labeled AMD_FAN_LED1.
Do you think I should try another slot?
https://linustechtips.com/topic/1635510-help-with-case/#findComment-16886980
take a pic of the hub
24 Addressable LED Header (ADDR_LED1) is the argb header
Edited by thrasher_565
https://linustechtips.com/topic/1635510-help-with-case/#findComment-16886983
Sorry for the dealy but here's some pics of the HUB -
The cables on the second pic are not connected at all, I thought they were for "Daisy chaining" the fans into a singular slot
https://linustechtips.com/topic/1635510-help-with-case/#findComment-16887064
whats the port look like on the aura
reset  button should be the button for the argb control.
https://linustechtips.com/topic/1635510-help-with-case/#findComment-16887150
  • 2 weeks later...
