Hey, is there any way without buying a voltage restrict to lower the rpm of a 3 pin fan? too loud :(
CPU: AMD Phenom II X4 965 @ 4Ghz | Cooler: Corsair H80i | Case: Corsair 300R | Motherbord: Gigabyte 990FXA-UD3| RAM: Corsair Vengeance 8GB 1600MHz White |
Graphics Card: MSI GTX 680 Twin Frozr OC | Power Supply: Corsair CX750 | SSD: Kingston HyperX 3K 120GB
https://linustechtips.com/topic/16341-voltage-restrict-a-fan/
You may be able to change the voltage from your motherboard through the BIOS or software you can install. Personally i don't do it because it does not work on all boards and your better off just buying a cheap fan controler.
https://linustechtips.com/topic/16341-voltage-restrict-a-fan/#findComment-185598
This should be in the Air Cooling section but, oh well.
Fan adapters (There are 7v, 5v, etc versions depending on how slow you want them):
http://www.amazon.com/Phobya-Adapter-Converts-voltage-Sleeving/dp/B00943Q4C2/ref=sr_1_6?ie=UTF8&qid=1368549553&sr=8-6&keywords=fan+voltage+reducer
DIY way:
https://linustechtips.com/topic/16341-voltage-restrict-a-fan/#findComment-185602
yeah probably should haha, thanks! :)
https://linustechtips.com/topic/16341-voltage-restrict-a-fan/#findComment-185608
