i have a 4090 + 7800x3d with 48gb of 7000mt/s memory, however when i play overwatch im struggling to keep 300fps and stay at like 40% gpu usage.
i have tried everything from force enabling resizable bar in profile inspector and resetting windows, but it just stays at 40% roughly and sometimes goes over 300.
i have a 360hz monitor and 300fps is fine to play on, but theres clearly something going on when benchmarks show my same gpu with a worse CPU capping out at 600FPS on higher settings than i play at at 1440p. if anyone has any suggestions as to what may be going on id appreciate it.
https://linustechtips.com/topic/1633915-low-gpu-usage-in-overwatch/
If your GPU usage is at just 40%, that usually indicates that something else in your system is the limiting factor.
You say you've got DDR5-7000 memory. How did you validate that it was stable with the 7800X3D?
Most AM5 CPUs can't go above DDR5-6400 while maintaining a 1:1 Infinity Fabric ratio. Even getting DDR5-6400 to work can be non-trivial. DDR5-6000 is recommended because it's the level where 99.9% of CPUs can achieve it without issues.
One thing to keep in mind is that long-running multiplayer games change performance profiles over time so if you are looking at a benchmark from several years ago it might be somewhat irrelevant.
That said, one thing to check is your RAM settings. For Ryzen 7000 series, DDR5-6000 CL30 is actually the ideal spot and going to 7000 might actually worsen gaming performance because it forces the infinity fabric clock to drop down to half-speed.
"TV Gaming" PC: Ryzen 5 5600 :: 32GB DDR4-3200 :: RTX 2070 Super :: 500GB PCIe 3.0 SSD :: 1.5TB of SATA SSDs :: Windows 11
"Desk Gaming" PC: i5-4690K :: 16GB DDR3-1600 :: RX 560D 4GB :: 500GB SATA SSD :: Linux Mint 22
Office PC: Dell Pro 14 :: Ultra 7 268V :: 32GB DDR5-8533 :: 512GB PCIe 4.0 NVMe :: 6TB HDD :: Windows 11
Laptop: Dell Latitude 15.6" :: i5-4200U :: 8GB DDR3-1600 :: 500GB SATA SSD :: Linux Mint 22
Primary NAS: i5-7500 :: 16GB DDR4-2133 :: 250GB SSD :: 8TB HDD :: TrueNAS Scale 24.10
Web Server/Backup NAS: Raspberry Pi 4 Model B :: 2GB RAM :: 64GB microSD card :: 8TB HDD :: Raspberry Pi OS
Other tech stuff: iPad Pro M4 13" :: Samsung Galaxy A15 4GB :: 2022 Kindle Fire HD 7 :: PS4 Slim w/ 1TB SSD :: OG Nintendo Switch
I can run ow at over 300fps on a 5070 (and on a 3070 too!) so clearly something is wrong, might be your ram as mentioned.
But also what's the graphics settings?  I think if you set everything to low it won't use much of anything (I always max it out basically... It's a 2016 game after all!)
Yeah, that might be part of the issue...
-Scott Manley, 2021
The game is capped at 600 FPS.
