Budget (including currency): 2000Eur
Country: Croatia
Games, programs or workloads that it will be used for: Games like: Wot, warthunter, cod, gtav; programs: blender, davinci, autocad
Mainly gonna do 2k resolution, dual monitor setup.
Nead help to see if this is good in combination:
FSP M340 BA, Mid tower
Gigabyte B650 AORUS ELITE AX V2
AMD Ryzen 7 7700X Socket AM5
Kingston Fury Beast KF560C30BBEK2- 32, 32GB DDR5 5600MHz/6000MHz, CL30, (2x16GB)
Seasonic Powersupply Core Gx-750
ASRock Pro 360 ARGB, 3x120mm, Intel i AMD
All without graphic card is about ~1400€
Adn probably gonna get something like RTX5060Ti
Any suggestions what to replace or add.
https://linustechtips.com/topic/1632641-pc-build-help/
3 minutes ago, Gummybearzx said:
Price are +/-5%
How much is a 16GB kit? Personally I would save some money now and then upgrade if/when RAM prices come back down. 500 euros is absurd. Could then use that saved money for a better GPU if you still want to spend 2000 euro
Console.WriteLine("Hello World!");
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868215
Its cheaper to get 32gb kit then 16gb
Price for same brend Kingston Fury Beast KF560C30BBEK2- 16, 16GB DDR5 6000MHz, CL30, (2x8GB)  328,70 €
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868216
RAM prices seem to be a bit more insane than in most EU countries? (Here 32GB is ~ 400€) As other parts have reasonable price tags.
Pax vobiscum
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868218
Personally I would go with that option, then you have another 170 euro for your GPU
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868219
Just now, Tan3l6 said:
RAM prices seem to be a bit more insane than in most EU countries? As other parts have reasonable price tags.
Yeah, I'm based in the UK and my £80 kit of Vengeance is now £500, yikes
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868220
1 minute ago, Tan3l6 said:
Lowes its go is about 410€ from amazon de thats saves about 100€, but is crucial cl36 better than kingston cl30
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868223
I think CL30 vs 36 is not a big difference, couple of percentage on very high frame rates, worth a ~100€ saving in my opinion.
Benchmarks 30 vs 36 on 1440p there's no big difference:
Pax vobiscum
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868226
Country: Croatia
I think the 9060XT 16GB is a better GPU. Also, I'm not sure if you need an AIO cooler for the 7700X, but that's fine. Good choice on the RAM.
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868227
On 2/23/2026 at 3:19 PM, Gummybearzx said:
Ok, gonna look for benchmarks and price comparison to see what i will get.
9060xt is not a better GPU , just cheaper
5060Ti 16gb has better features overall .
although personally i would avoid both since they are priced too closely to rtx 5070 or radeon 9070 in most EU countries -
and those cards are 30-35% faster and the price difference is like 150 bucks which is worth it ...
with 2K budget you should be targeting radeon 9070XT
how are the prices for  B850 motherboards in your country ?
i7 8700K , Z370 K6 FATAL1TY , GTX 1080Ti rog strix , NOCTUA NH-D15S ,
2x16gb DDR4 3200MHz/cl16 , FRACTAL R5 window , EVGA G3 750w gold ,
480gb m.2 NVMe WD SN350 + 500gb SAMSUNG EVO 850 ,
creative sound blasterX AE-5 Plus , MSI Optix G241 , WINDOWS 10 PRO
https://linustechtips.com/topic/1632641-pc-build-help/#findComment-16868860
