Specs:
12900H
3080Ti 16GB 175W +25W adaptive boost
64GB 5600MHz Crucial SODIMM CL46
1TB Firecuda 530R
1TB Samsung 970 EVO
Intel BE200 WI-FI Card
99Wh battery (internal UPS anyone?)
280W Chicony Power Pack
Artic P12 Slim PWM fan
Summary:
This motherboard was salvaged from an XMG NEO E22. I didn't want the hardware to go to waste and decided to learn CAD with Fusion360 along with my P1S. It took a little over 2 months to wrap my head around Fusion and the different tricks to get somewhat prototype results.
This isn't the final chassis as I will be printing in an engineering filament at a later date. For now, it is a mixture of Matte PETG and PETG-CF.
Important details:
Laptops can be a little tricky to convert to a SFFPC, this is due to the MUX switching and how external ports are configured. To avoid issues, I wired in an EDP cable from the motherboard to a 40P EDP converter board, this offers a HDMI signal which is next to one of the exhaust vents. The brilliant thing about this addition is that I have BIOS & Windows access that is seamless.
Hardware & Temperatures:
As you can imagine, with the chassis getting plenty of airflow, there is no issues with internal temperatures. With a highly configurable BIOS and control centre software, I have tuned in a -30mv CPU offset, along with a 10c TJ Max offset.
I also achieve maximum GPU performance with a temperature limit of 80c, the results in very low fan noise and all available performance.
To create a solid chassis, I used threaded inserts and a dedicated motherboard tray that is centre to the chassis. Everything is mounted with either M2 or M3 hex hardware.
Overall, I am incredibly pleased with the result and I now have something unique.
IMG_2558.thumb.jpg.2001f1f2777b0651f06fe79ccd1b835d.jpgIMG_2561.thumb.jpg.445db1b1af1527b4e557b0138dafc395.jpgIMG_2544.thumb.jpg.247d46f96fbe9943a04587303be29f06.jpgIMG_2566.thumb.jpg.d3518ede20047cb750b6eeb1478736d5.jpgIMG_2565.thumb.jpg.381b3a844200b0333f4cf90260309f58.jpg1df4d093-60dd-47ec-a013-e812fad2a8ab.thumb.jpg.a2420d676e54b7b674a3e5e3eba57d92.jpg
https://linustechtips.com/topic/1631000-project-upcycle/
I wasn't browsing LTT expecting to get turned on like this
Celebrity gif. James McAvoy leans back in an office chair, face glistening with sweat. He breathes in and out heavily, fanning himself with papers.
Sick build. I love the upcycling, I love the design, I love the outcome.
9/10
10/10 when you get it properly printed.
I sell teeth and teeth accessories 🦷
https://linustechtips.com/topic/1631000-project-upcycle/#findComment-16857653
Neat! Don't think there's a point to reprint in more fancy filaments though, PETG should be fine for anything PC-related. If the case is reaching PETG glass transition temps there's something wrong with the cooling anyway.
F@H
GPD Win 2
https://linustechtips.com/topic/1631000-project-upcycle/#findComment-16857663
Some QOL changes.
  • Opted for printed heatsink fan covers instead of the traditional tape/mylar.
  • M.2 heatsink with centre pad cut away, allows both DDR5 SPD's to be cooled effectively.
  • EDP to HDMI converter board for HDMI spoof - debug display if required. No longer encounters ACPI BSOD during boot sequence due to missing internal display.1.thumb.jpg.074a91587ac9cddcca211cbb4f6aba56.jpg2.thumb.jpg.6c2084f7353c5d60c399a0307b840322.jpg3.thumb.jpg.eaff52d3c46bcbd2e8734090f13cde71.jpg
https://linustechtips.com/topic/1631000-project-upcycle/#findComment-16858128
  • 2 weeks later...
