GPU upgrade help
Go to solution Solved by OddOod,
Just now, aikka said:
Thanks for the responses, its much appreciated.
The RTX 5070 Ti seems like a good option, though I was wondering if there are more options or if this is one of the better cards in terms of price to performance you can get atm. Also why would it be better (or not) than other options?
At the moment, I'd actually recommend just getting the 5070ti because it's gonna come with a warranty and given how the AI bubble is driving prices up, it can be nice to *know* you'll have a good GPU for at least 3 years
Budget (including currency): around 800 euro
Country: Netherlands
Games, programs or workloads that it will be used for: I mainly use my system for heavy 3D work like simulation, asset creation and rendering in Houdini and work in Unreal. Though its also my main gaming pc where I play AAA games like Expedition 33 and Horizon.
Current specs:
Motherboard:
ASUS ROG STRIX Z790-E GAMING WIFI DDR5
CPU: Intel Core i7 13700K
GPU: GTX 1080
RAM: G.SKILL Trident Z5 2 x 32 GB 288-PIN DDR5 6000 MHz
Power supply: Corsair HX1200i
Monitors: 2x 4K 60 Hz monitors (will probably upgrade for a higher refresh rate at some point)
I originally built my pc in 2016-2017 though I've had to upgrade my CPU, RAM and motherboard due to it being quite outdated, and my Windows version no longer supporting my PC hardware.
The desktop is mainly used for work-related stuff in Houdini and Unreal so combined with good graphics, that's the main priority. That said I would very much like to be able to play most new and upcoming games on the higher end of settings on a 4K screen if possible.
My main aim is something that is a bit feature-proof for a year of 5 and doesn't to far exceed what other hardware I currently have, as aside from my monitor, I don't plan to upgrade it anytime soon.
I'd like an NVIDIA GPU as that's what I'm used to so far, though I'm open to AMD if its would be significantly better.
I'm kinda lost on what to look at at this point, so some advice would be much appreciated.
Thanks in advance.
https://linustechtips.com/topic/1630058-gpu-upgrade-help/
Welcome to the forums!
Are you significantly bottlenecked by your current CPU cores? If not, I'd recommend just dumping all the money into a used GPU, especially if your workloads are GPU accelerated.
https://linustechtips.com/topic/1630058-gpu-upgrade-help/#findComment-16850265
PCPartPicker Part List
Video Card: *PNY OC GeForce RTX 5070 Ti 16 GB Video Card  (€799.00 @ Azerty)
Total: €799.00
Generated by PCPartPicker 2026-01-08 20:52 CET+0100
https://linustechtips.com/topic/1630058-gpu-upgrade-help/#findComment-16850270
For 800 euro you can buy an RTX 5070 Ti. There is no faster card for that much money as it beats out the AMD RX 9070 XT, which is €70 less. The 5070 Ti can play most games at 4K using DLSS upscaling. You can't get a faster card without spending €1,000 for an RTX 5080, or finding a high-end used card.
Welcome to the forum 🙂
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/1630058-gpu-upgrade-help/#findComment-16850272
The RTX 5070 Ti seems like a good option, though I was wondering if there are more options. This card is directly at my max or slightly above the budget after all. So is it really so much better in terms of price to performance than other cards within the budget, and if so, why (or why not) compared to others?
https://linustechtips.com/topic/1630058-gpu-upgrade-help/#findComment-16850292
https://linustechtips.com/topic/1630058-gpu-upgrade-help/#findComment-16850294
5070TI no question
https://linustechtips.com/topic/1630058-gpu-upgrade-help/#findComment-16850315
