Advice for Upgrading CPU
Go to solution Solved by Dedayog,
9 minutes ago, austing316 said:
Budget (including currency): preferably $500
Country: United States
Games, programs or workloads that it will be used for: Strictly gaming
Current Specs:
Motherboard: MSI B150M MORTAR ARCTIC LGA 1151
CPU: i5-6600K 6M Skylake Quad-Core 3.5 GHz
GPU: Geforce GTX 1070
RAM: CORSAIR Vengeance LPX 16GB (2 x 8GB) 288-Pin PC RAM DDR4 2133
Power SupplyRosewill HIVE-750S
Monitor: (1) monitor AOC (not sure of model, but it's 60 Hz) *would prefer two monitors but will wait to upgrade*
Extra: I have a new(ish) m.2 SSD (980 Pro PCIe 4.0) that I can't use due to the CPU being 6th generation 😕. I'm currently using a 256Gb SSD for OS and a 2Tb SSD for everything else.
Built back in 2014.. the graphics card seems to hold up well with medium-high settings in most games, but the CPU is maxed at 95-100% (all non-essential programs and overlays closed) causing tons of stuttering/freezes/etc.. I've tried searching and using every tip in minimizing CPU usage (both in-game and OS side), but it seems to be my first bottleneck.. so this is where I'm wanting to start the upgrade process.
Looking for any advice on choosing a new CPU/motherboard. Currently looking at an AMD Ryzen 5 7600X CPU with MSI PRO B850-P Motherboard. Only concern is DDR5 ram which seems to have skyrocketed in price. Wasn't sure if DDR5 will be necessary for future-proofing my PC or not..
Thanks in advance for any help 🙂
Ryzen 5700X and a B550 motherboard, reuse your DDR4 RAM and try to bump it to 2400MT/s or more.
DDR5 is wasted until you get a much better GPU, to be perfectly honest.
Current Specs:
https://linustechtips.com/topic/1629916-advice-for-upgrading-cpu/
Current Specs:
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
1 hour ago, austing316 said:
5700x and not the 5700x3d .. correct?
Unless you can find a 5700x3d cheap!
OnePlus Ecosystem:
3D Printing:
