10 minutes ago, Robert nox1ous said:
Hello guys can you please help me identify the problem? After a restart, it goes back to normal, but then acts up again.
I guess it didn't do this when you first got it. Try tilting the lid back and forth and see if it resolves the issue. My guess is that you got a bad display cable. 馃檪
Gaming PC:
CPU: Ryzen 5800X3D |聽Motherboard: Gigabyte B550聽Elite V2 |聽RAM: Crucial 2x16gb, 3200聽 JEDEC.聽|聽PSU:聽EVGA SuperNova聽750 G3 |聽Monitor:聽LG 27GL850-B , Samsung C27HG70 |聽
GPU: Asus Prime RTX 5070ti OC|聽Sound: Odac + Fiio E09K |聽Case:聽Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb |聽Cooling:聽CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo聽
Linux PC:
CPU: Ryzen 7700|聽Motherboard: Asus A620M-CSM |聽RAM: Crucial Pro 2x48gb, 5600聽 JEDEC.聽|聽PSU: Corsair CX750 |聽Monitor:聽LG 27GL850-B , Samsung C27HG70 |聽
GPU: MSI Gaming X RTX 3090聽|聽Case: Lian Li Dan Cases聽A3-mATX black聽|Storage: SN7100 2TB + Samsung 860 EVO 512gb聽|聽Cooling:聽CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
Tilting it back and forth works, but after some time, it acts up again.
Ok and it doesn't disappear after some time? Is it very hot where you're at? Whats the model of the laptop? If the panel is display is VA, it could be because the temperature of the display is getting either too hot or cold.聽
Gaming PC:
Linux PC:
Once I聽on the laptop, after a few minutes it acts up even if the laptop temperature is not hot also.
It's more the screen panel temp but I would try changing the cable anyway.
Gaming PC:
Linux PC:
