BSOD has happened to me a hand full of times that I'm at the point where I want to know what's causing it so I can hopefully fix and prevent it from happening. What are the ways to troubleshoot this and finding out what is causing the BSOD? It's a quick flash of the BSOD to a restart. What can I check so I can see what's causing it. I do not think it is hardware related, my PC is only a bit over a year old and it only started at the minimum date of 8/19/25. Here's my build though:
CPU: Ryzen 7800X3D
RAM: G.Skill Flare X5 Series DDR5 RAM 32GB (2x16GB) 6000MT/s
Mobo: Gigabyte B650 Gaming X AX v2
GPU: Zotac GAMING Trinity GeForce RTX 4070 Ti SUPER 16 GB
Storage: Silicon Power UD902TB 4.0 SSD NVMe 4.0 Gen3 PCIe M.2 SSD R/w up to 5000/4800 Mb/s
Windows 11 23H2, I do not want to update to 24h.
Does anyone have input so I can hopefully figure out what's wrong? Could it be BIOs related? I have done a registry edit to disable windows updates, could it be that?
https://linustechtips.com/topic/1627437-blue-screen-help/
