Hello everyone!
I've recently built a rig and in my opinion its pretty dang good. My specs include a GTX 770, and i7-4770k at 4.0 ghz. and the rest doesn't really matter for this situation. I've had the rig for about 4 months now, and consistently I've been hitting exactly 60 fps on all my games. I'm not sure how to change it to go above. I've heard its something to do with Nvidia settings. Thanks!
https://linustechtips.com/topic/162680-maxed-fps-please-help/
The question is: Do you need more than 60fps? I dont think so.
But there might be a v-sync setting in the control panel. I would actually keep adaptive v-sync enabled.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/162680-maxed-fps-please-help/#findComment-2165267
In all games disable Vsync... you won't notice any difference since that syncs. (your monitor is 60 Hz, it'll display 60 FPS everytime, even if you get 180 FPS) with your monitor if you want more buy a 120 Hz monitor :D
The thing is, i do. I have a 144hz moniter with a 1 millisecond refresh rate.
https://linustechtips.com/topic/162680-maxed-fps-please-help/#findComment-2165276
But it wont let me go higher than 60hz in the settings...
Are you using HDMI? Some monitors come with old HDMI inputs that don't go higher than 60. Might have to buy a display port cable or see if DVI can go higher.
CPU: i7 4770k CPU Cooler: Corsair H100i Mobo: Gigabyte z87 ud3h Memory: 16GB Corsair Veng. 1866MHz  GPU: EVGA SC 780 PSU: Corsair ax850 Case: Define R4 BlackOut Edition SSD: Samsung 840 EVO HDD: Two WD Black 7200RPM 1TB
https://linustechtips.com/topic/162680-maxed-fps-please-help/#findComment-2165313
I do have an HMDI hookup. This is quite disappointing, not being able to have my 144hz monitor above 60hz.
https://linustechtips.com/topic/162680-maxed-fps-please-help/#findComment-2165325
I meant in games :P:
^-This... I forgot about this
DVI-D Dual link and DP are your best friends for high refresh rates and resolutions
How do you tell whats DVI-D and what is a different kind of DVI? If such a cable exists as i dont know my monitor cables very well... xD
https://linustechtips.com/topic/162680-maxed-fps-please-help/#findComment-2165342
Display port is the next gen standard.  4K monitors require Display port connections.  Full digital and higher bandwith = higher resolution.
My build:  Leviathan  Case: 900D  CPU: i7 3770K (watercooled)  Mobo: Z77X-UD5H GPU: EVGA GTX 780 Hydro Copper GPU: MSI GTX 780 watercooled PSU: EVGA 1300W G2  RAM: 32 GB Corsair Vengance  HDDs: 1 x 120 GB Intel 330 SSD (OS X); 1 x 256 GB Samsung 840 pro (Windows 8); 2 x 2TB Seagate Barracuda (RAID 0 Data OS X); 1 x 3TB Seagate Barracuda (OS X backups)  Monitors: 1 x 24" Apple LED Cinema (center); 2 x 23" Apple LED Cinema (surround)  Watercooling: 3 rads, CPU, GPU, GPU, MCP655 pump, Lots of fittings, EK reservoir, EK UV Blue coolant.  Updated build: Leviathan 2.0
https://linustechtips.com/topic/162680-maxed-fps-please-help/#findComment-2165637
