First PC build australia.
Go to solution Solved by Why_Me,
PCPartPicker Part List
CPU: *AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor  ($299.00 @ Storm Computers)
CPU Cooler: *Thermalright Peerless Assassin 90 SE 32.77 CFM CPU Cooler  ($56.74 @ Amazon Australia)
Motherboard: *Gigabyte B650 EAGLE AX ATX AM5 Motherboard  ($227.00 @ Centre Com)
Memory: *TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($215.00 @ PLE Computers)
Storage: *Klevv CRAS C910 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($159.00 @ MSY Technology)
Video Card: *MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card  ($419.00 @ Centre Com)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($69.00 @ PLE Computers)
Power Supply: *MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  ($65.00 @ Centre Com)
Total: $1509.74
Generated by PCPartPicker 2025-10-21 14:29 AEDT+1100
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
Budget (including currency): 1500 AUD (can go over a bit)
Country: Australia
Games, programs or workloads that it will be used for: casual games (coral island, stardew etc), & story games like until dawn, GTA, RDR2, Witcher etc. Also some uni work.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): not sure
I don't know too much about building PC's but i've done a bit of research & think I'd prefer to go with AMD over intel & my brother keeps telling me to go with a NVIDIA 3060 or higher for gpu? Also I would prefer a white case if possible & if within budget just coz it will match my current desk setup better (but trying not to be too fussy since my budget is quite low). This stuff confuses me lol & any help would be much appreciated, thanks 🙂
https://linustechtips.com/topic/1625099-first-pc-build-australia/
Country: Australia
Here's a build with a white case, if you want i can change it to try and include a white motherboard and gpu. https://pcpartpicker.com/list/p7nRrM
hey! thanks so much for replying. Unfortunately that goes over my budget quite a bit as I use AUD,, is there any way for it to be around 1500 AUD (with some wiggle room) as that came to around $2360. Thanks again ! 🙂
sorry about that, I have it fixed https://au.pcpartpicker.com/list/RvkQmC
Total: $1509.74
If u get good deal go for rx 9070 non xt
Amd Ryzen 5 5600 Zen 3 OC 4.6Ghz
RTX 3070 gaming gigabyte
32GB patriot 3600 MHz
Casual gamer since dune 2 and wolf 3d and dukem nukem 3d
https://pcpartpicker.com/user/apokhallipsa/saved/j4rn23
Total: $1509.74
Wot ? You're recommending a board that's being phased out with no PCie5 GPU slot ? 😄
