Are my temps normal?
Go to solution Solved by thrasher_565,
ya that's normal
+1, very normal (good even!) temps.
85c is where it begins to get a bit toasty (above 85c you may be loosing slight performance due to lower boost clocks), and the CPU can handle up to 100c before it becomes at risk of damage.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1624402-are-my-temps-normal/#findComment-16810680
