Looking for linux options, hope to move from windows but need a good option for my new pc, need an operating system that deals with web browsing and running multiple browsers with multiple tabs open and is good with watching videos or movies but is also very good at playing games and is easy to use, would prefer something similar to windows look wise as i am used to that. any thoughts as i really want to move from windows and this could be the right time, i will be able to test it out on my older laptop to see what i think.thanks
https://linustechtips.com/topic/1623897-os-help/
The difficulty is with the games and the Desktop Environment, and not the Distribution.
The most recommend Distribution is Linux Mint and either the Cinnamon or Mate Desktop Environments.  Others are either Zorin or Q4OS. But there are others
For gaming Bazzite is highly rated.
For browsers themselves, there are Mozilla Firefox, Chromium, Google Chrome, Brave, Opera, SeaMonkey, Vivaldi, Tor, LYNX, Microsoft Edge, Opera, Vivaldi, Midori, Epiphany,Falkon, among many others. NOTE: Not all of these are available from a particular Distributions App Store but can be installed from either the developers own website or other on-line site,
I recommend that if you're not sure and want to experiment first is to download and install Ventoy, it's the one I use to make a bootable Flash drive where you can copy the different .iso files and when booting from it allows you to choose which one you want to live boot into.
Live booting install the distribution into RAM and allows you to familiarize yourself with it. It does not have any effect with whats already on the computer already and when you close it when you're done, clears everything from the RAM and when you reboot it's like it was never there.
https://linustechtips.com/topic/1623897-os-help/#findComment-16807231
^^ +1 for Bazzite. It'll ship with KDE Plasma (the desktop environment, how the operating system looks basically) which defaults to a windows-like layout. It defaults to a nice app store for Flatpaks (a way of packaging apps) and there's a Flatpak for about everything you could want. And it's on a current kernel (core of the OS itself, lots of drivers and fixes for the ways apps talk to your hardware are in here) not held back multiple versions like Linux Mint - or any Ubuntu LTS based OS - is. For gaming, the Flatpak version of Steam can have some issues if you use multiple drives, but if you're just installing to your main drive like normal, it's fine in my experience so far.
In less-linux speak: Bazzite is nice, it looks similar enough to Windows that you'll have little problem adjusting, and it has a simple GUI App Store to install about anything you can think of.
If you want to get in deeper, you can look into what an "immutable distro" is and how it works. Bazzite is one, it's based on Fedora Silverblue and they just add everything you need for normal gaming, so you don't have to think about it or figure it out. Regular Fedora is nice (I again recommend the KDE Plasma spin of that) if you don't want an immutable distro. I didn't have issues running games there either.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1623897-os-help/#findComment-16807247
Which games? Because if you’re just playing games that are Steam Deck Verified or Playable, the Bazzite will be great.
If you want to play popular online multiplayer titles, Linux will not be the most fun you’ve ever had.
https://linustechtips.com/topic/1623897-os-help/#findComment-16807477
hi, will be mostly be single player games like cyberpunk or Indiana jones things like that.
https://linustechtips.com/topic/1623897-os-help/#findComment-16807536
thanks for the advice about the live boot will try that
https://linustechtips.com/topic/1623897-os-help/#findComment-16807538
On 10/1/2025 at 3:04 AM, Thomas53 said:
Vivaldi, Falkon
These are my two favourites. Vivaldi is my "daily driver", Falkon is for my bank, supermarket and "regular suppliers".
On 10/1/2025 at 3:38 AM, Zando_ said:
KDE Plasma
This my recommendation for "windows users"; I used it for years whilst still forced to use windows professionally and it has the smallest "paradigm shift" to be able to use both. If it's non-power users I tend to recommend the default mint environment (Cinnamon?), it's settings GUI is less "busy" - but both are easier to navigate than Win8+
8 hours ago, Thomas53 said:
Bazzite
On 10/1/2025 at 7:58 AM, TudorFinalBosz said:
CachyOS
I don't use either, but hear the scuttlebutt and both are strong contenders.
On 10/1/2025 at 2:32 AM, JohnLee19869 said:
my new pc
How new? Not is an "new to me" but as in "how long has this chipset been available": If it's "very new" we can do some cursory research on drivers, which may sway your decision.
https://linustechtips.com/topic/1623897-os-help/#findComment-16807787
If your computer was made any time after 1950, there is at least one or two Linux distributions that will work in it, you'll just need to do some research.
https://linustechtips.com/topic/1623897-os-help/#findComment-16807838
As someone who has been building their own kernel for over 20 years, I can quite confidently say you have no idea what you are talking about, but that's OK, users from all across the experience spectrum post here, that's what makes it unique.
https://linustechtips.com/topic/1623897-os-help/#findComment-16808009
As that most users don't build their own kernel, I stand by my suggestion. And for those that do, I congratulate you on your efforts and encourage more people to do so.
And specifically as a new user, it more likely that he will cause himself more problems than what it's worth. After some time using a new OS, then it's a good idea to learn how to rebuild the engine and know what parts aren't needed.
https://linustechtips.com/topic/1623897-os-help/#findComment-16808598
