I had an NVME ssd that served as my C: drive. For a while, I was getting a lot of blue screens, until one day the drive simply stopped working completely. When I switched to a new C: drive, I never got those BSOD again, meaning that either the drive or the port is damaged. The problem is that I can no longer access any of the data in that ssd, as Windows tells me that I need to format the disk to open it. I tried running chkdsk, but it said this: "The type of the file system is NTFS. The first NTFS boot sector is unreadable or corrupt. Reading second NTFS boot sector instead. Unable to determine volume version and state. CHKDSK aborted." Unfortunately, my motherboard has no other NVME port for me to test whether the ssd can be read in another port.
https://linustechtips.com/topic/1622985-i-need-help-with-data-recovery/
There are USB thingamojings you can put the drive in and connect to the pc to try with, but it's no guarantee it would detect the drive especially if it's going bad.
I usually edit my posts.
Refresh the page before answering to my post.
It’s possible that it is just a partition table corruption.
do not perform any write operation on that Ssd,  do not format, do not chkdsk ( disable trim for it if you can )
you can try to run some liveCD Linux distro, like Ubuntu and see if it can see the files, if it can, just copy it to other drive.
you should also run crystaldiskinfo and post here a screen from it of that Ssd, for us to see if there’s anything wrong with it from smart data.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
You need software that reads a drive as raw data, not partitions. Which can recover files based on headers, but if they are contiguous. I've used something like that once, but don't remember what it was called.
Since it can't find the partition table, there's no way to recover fragmented files.
You could try a tool that rebuilds the drive headers. But that would make the old structure gone.
I don't even understand how could an SSD have such errors, I thought when they go bad, they become read-only. Was there some software intervention on the drive? Or sudden power cut while it was writing?
Probably best solution would be to use disk cloning software, to make sure you recover as much as possible, but it will be just raw data. A soup of characters that maybe later could be made sense of by looking for file headers.
But if no software can read it even as raw data, then maybe the drive is electronically damaged.
I haven't tried it myself, but maybe DiskGenius could repair partition tables and such things?
It's a free app but I've only used it for OS migration, haven't had any usage for its other functions.
@kokosnh @TudorFinalBosz
I would think that even with raw data, there'd likely be a layer of encryption on the controller firmware level preventing easy translation back to usable data.
Usually when the drive fails to this degree, error correction has been overwhelmed to the point that enough bits have been corrupted that it can't recover enough to get the user's data.
rat
