7 minutes ago, KodokuSusie said:
My motherboard's second slot from the CPU isn't working/letting the PC post. Since you're supposed to do slots 2 and 4, but that's not an option what 2 slots are best to use?
If it's for dual channel, then the other pair of slots.
They usually give which pairs with which for dual channel in the motherboard manual.
Refresh before you reply
https://linustechtips.com/topic/1621040-memory-slot-issue/#findComment-16787834
Try the other two slots.
https://linustechtips.com/topic/1621040-memory-slot-issue/#findComment-16788052
8 hours ago, KodokuSusie said:
Did they work?
https://linustechtips.com/topic/1621040-memory-slot-issue/#findComment-16788482
