Hi guys
I just ordered a pure power 13m PSU but I'm not sure if it's gonna fit in my phanteks xt m3 case where I can't find the dimensions for it anywhere or if it won't fit will the seasonic vertex PSU fit any help and guidance would be much appreciated because I'm not sure if the pure 13m from be quiet doesn't fit what to do at this point I might just have to order the seasonic vertex PSU but I'm not sure if it will fit either where I can't find the dimensions. Any help and guidance would be much appreciated. Also the phanteks xt m3 only supports a maximum of 150mm for the PSU.
https://linustechtips.com/topic/1620423-advice/
The Pure Power 13 M is 16 cm long. You can find the length on Be Quiet's product page.
One of the product images for the case claims up to 16cm long PSUs are supported, so there might be enough room for it, despite the 15cm indicated in the specs.
The product pages for PSUs include their dimensions. It should be one of the first places to look for that kind of stuff.
https://linustechtips.com/topic/1620423-advice/#findComment-16783753
When the pure power 13m gets here tomorrow I watched a video on it and person on the video explained that the pure power 13m was a tier A power supply and that it was a very good reliable brand of PSU hopefully that's true because I watched another video from Jayztwocents and he said in a video that be quiet is a very reliable PSU brand. I was thinking about going the seasonic vertex PSU hopefully I didn't make a mistake because I don't want to have a PSU that will potentially fry my PC within a year or two.
https://linustechtips.com/topic/1620423-advice/#findComment-16783769
According to the PSU Tier List the Dark Power 13 and the Pure Power 11 and 12 are all A tier
https://linustechtips.com/topic/1620423-advice/#findComment-16783776
I've been told before that I'm old-timer because I was referring to that "old" PSU tier list. (Last updated 2023-04-11)
All the cool kids follow - This excel table I've been told. But nevertheless Dark Power 13 is good. Pure Power 11 and 12 not a tier necessarily.
Pax vobiscum
https://linustechtips.com/topic/1620423-advice/#findComment-16783781
