Hello,
I built a PC in January earlier this year with the following specs: Intel i5-12400F, Corsair Vengeance 2x16GB DDR4 3200MHz, MSI VENTUS 3X OC RTX 3070, ASUS B760M AYW WIFI DDR4, MSI MAG A650BN. Until around a month ago, the PC was working fine with no issues. However, now when the power button is pressed, the lights on the button flash constantly, about twice every second. The RGB turns on, and the fans spin. This however keeps on going, and the PC will not boot. The only way to turn the PC on was to repeatedly turn it on and off for around 15-20 minutes. Once turned on though, the PC ran perfectly fine, with no issues. Now the PC will not turn on at all, even after 2 hours of attempts, with the RGB and fans repeating the same behaviour. I am just wondering what the issue is, cause I have removed the GPU and RAM, and reset the CMOS, and yet the PC still doesn't run.
https://linustechtips.com/topic/1620404-pc-will-not-boot/
When the PC is turned on but is not posting, do you see any LEDs lit up on the motherboard? I'm thinking of the debug LEDs.
Example pic:
Expanded Image
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1620404-pc-will-not-boot/#findComment-16783581
3 minutes ago, budui said:
I don't think I have debug LEDS on this motherboard
Oh what the hell, yeah, just looked at a photo of your motherboard and it seems like there's no debug LEDs... Huh, thought that was default on all motherboards. Do you have a beep speaker?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1620404-pc-will-not-boot/#findComment-16783587
Slow blinking on the power button
could be gpu or boot device
does the display do anything ?
do you have another drive or can you try to reinstall windows ?
Edit : you probably meant gpu,
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1620404-pc-will-not-boot/#findComment-16783592
Also I don't know if this provides any more detail, but if I put the PC to sleep, and then try waking it up, the display doesn't show anything, but the RGB lights up, and the fans start spinning.
I never use sleep & co, I turn off.
Does your issue persist if you turn off ?
https://linustechtips.com/topic/1620404-pc-will-not-boot/#findComment-16783603
7 hours ago, budui said:
I tried the paper clip test with a wire, and nothing happened, so the psu is probably fried
The paper clip test does not provide much insight, as the PSU could be on but the fan may not spin unless the temperatures rise.
Voltages and consistency could still be off, and without proper measurement equipment, it's impossible to pinpoint exactly what's failing.
Try a new PSU and see what happens, it might also be worth checking if the warranty is still available.
P.S. You might want to check out LTTLabs PSU tests. Personally, I’d recommend going with a Seasonic or Corsair
https://linustechtips.com/topic/1620404-pc-will-not-boot/#findComment-16783856
