Does anyone have any issues playing on 2560x1080? Im getting white artifacts everywhere when i run this resolution but when i switch to my second monitor running at 1080p, i do not get any artifacts at all. Right now im validating the steam files to see if there is an issue.
i7-2600K | ASRock Z77 Pro4 | ASUS 980 Ti Hybrid | Kingston 4x 4GB | EVGA Supernova 750 G2 Phantek Enthoo Luxe
Creative X7 Limited | 1TB WD Blue | 2TB WD Green | 256GB Liteon SSD | 240GB Kingston SSD | Corsair H100i
Logitech G502 Proteus Core | Logitech G710+ | LG 34UM65 | LG 27EA31V - B | AKG K7XX Massdrop | Windows 10 Pro 64-bit
https://linustechtips.com/topic/162009-wolfenstein-artifact-issue/
Maybe check your drivers? Having artifacts in games can sometimes be due to poorly optimized drivers.
Odd resulutions like yours can sometimes make for issues when you run games, and updating graphics drivers do sometimes solve the problems you might encounter.
If your GPU manufacturer did not give updated drivers optimized for Wolfenstein, you will have to wait, and update your drivers then.
Hope his helps ;)
That French guy who lives in the Netherlands and speaks German.
its pretty bizzare because running at 1080p on my second monitor runs perfect, just on 2560x1080 its artifacting everywhere. I thought it was my GPU dying, but i booted up watchdogs and it has no artifacts so thats out of the question. Steam is still validating my files cause from the steam forums its pretty isolated case. I think some texture files probably got corrupt.
Woops looks like my brower entered it twice. Also im going to note that im going to do all the "fixes" the devs said to do. Triple buffering may be cauysing it but i dont know how
I think i fixed it. Turning off triple buffering removed the artifacting problems i was having.
