My motherboard hasn't got a argb header so i brought the thermalright fan and rgb hub without realising that I will need a argb header to be able to use the lighting on my fans so i am trying to figure out what i can do to get them working.
using 6 thermalright tl-s12 fans but will be getting some more soon as at the moment i am mismatching fans
mbo is asus prime a520m-k
p.s I'm uk based
https://linustechtips.com/topic/1618839-rgb-help/
p.s I'm uk based
Most likely you need an RGB hub that connects to the motherboard through USB2, at least if you want to be able to control the lighting through software.
Most likely you will need to use the hub's manufacturer software though, unless there is a universal one out there.
No idea if the software gonna play nice with your fans
Refresh before you reply
https://linustechtips.com/topic/1618839-rgb-help/#findComment-16773932
what would you sugget i should use as was thinking of changing mbo and get a new cpu as running https://uk.pcpartpicker.com/list/XP4yNz
https://linustechtips.com/topic/1618839-rgb-help/#findComment-16773933
hub? no idea, i never used one.
dont wanna give you recommendation that turns out not working for you
https://linustechtips.com/topic/1618839-rgb-help/#findComment-16773934
